Has anyone found a touch up paint that is close to the blue on the newer (2016-up) Element boats? I understand it's gel coat but not getting into that for some scratches that are fine lined.
Element Blue touch-up match
First, will the scratches buff out? If not, (and I know you mentioned paint) Spectrum Color has gelcoat repair for our boats, it's listed under US Marine as the manufacturer. You can get a spray can of gelcoat. You can download their catalog from spectrumcolor.com I believe the blue you're looking for is called Patriot Blue Max. You can buy it on iboats.com - which is where spectrum color will direct you, if you try to buy on their website. You can buy a paste kit, which is super simple to use, quarts, gallons, and a spray can.'17 F18 - 115 Merc
Originally posted by shores View PostThese couple are a bit deep even for wet sanding. Well past buffing. Thank you for the color. I guess my point is not to spend $50 for a couple tiny scratches. Just wondering if anyone has found a close match in say dupli-color.'17 F18 - 115 Merc
Originally posted by shores View PostIf I find one I will report back.
Looks like you have a 115hp F18, mind if I ask what your #'s are performance wise?
1. what rpm and gps top speed?
2. what prop are you running?
3. what is your engine height or hole #?'17 F18 - 115 Merc
Originally posted by shores View PostStock prop is 15p 3 blade alum. Engine height is 2nd hole from top. Have you changed the prop or engine height?
BTW, I used to live on grand island.'17 F18 - 115 Merc
