Winter storage question - yeah I know, but thinking ahead
    For those in snow country and especially those that store their boat outside, do you pull your cushions out for the winter? On our old pontoon boat it wasn't an option, but I did open all compartments before putting the cover on for the winter.
    I bring all my removable cushions in the house for the winter...……….just in case some critter tries to use my slumbering boat as a winter condo.
    I figure there is less to be damaged if removed.
    It also prevents lots of hot/cold/dry/moist cycles on the threads and vinyl.
    • CparkerE16
      CparkerE16 commented
      Makes sense. And I'd prefer to have all those compartments open to let air circulate a bit and not get mildew
    +1....I also add a “Damp Rid” container to each compartment/storage location. Then I throw dryer sheets everywhere...rumor has it that the critters don’t like the sheets...for about $1.50 a box I figured why not. I don’t know if they do in fact keep the critters out, but the boat sure smells nice when taking the cover off in spring!
    Lake Hartwell, GA
    2012 BR 185 - 3.0 TKS
    1987 SeaRay 300 - Twin 454’s
    1995 Yamaha Waverunner III GP
    1996 SeaDoo GTX
    1999 SeaDoo GTX
      Was just thinking this tonight as I was cleaning up the boat. It will be our first winter with it, I think I'm going to pull all the cushions and keep them in the basement. We get enough mice in our garage, I can only imagine how many will end up in the boat this winter!
        indoor garage storage:
        I put a shot-glass containing oil of Wintergreen (available at your local drugstore) in each cup holder. I was told the rodents don’t like the smell, then I cover the boat so as to keep the odor contained. However, I do bring my cushions and battery in the house. If covering your boat, make sure it’s not air tight. Temperature will vary which will cause mold if air can’t circulate. Don’t forget to store your outboard motor completely down so that all water will run out. One more thing, remove the bilge plug(s) and store with the bow raised a bit, again this will allow any water in the hull to drain. To prevent those oval shaped tires in the spring, caused by long storage, I jack up my trailer/boat just enough to keep the tires off the floor.
        Parry Sound, Ontario Canada
        12 foot aluminum fishing boat
