Bayliner Element 16 E gas tank-gctid822378
    Often when checking my gas tank it seems to be collapsed. It's like there is a vacuum created. I know when it sits full it will build up some pressure but the tag on the tank said this is normal. Has anyone experienced the collapse?
    Sounds like your gas cap is not venting properly. You may want to look at replacing the cap and see if that fixes your problem.
    2014 Flight Package 16' Element
    Upgrades: 90HP Merc, NFB Helm, Smart Tabs, 4 Blade 15P Prop, MercMonitor Gauge, Bimini Top, Custom Steering Wheel, Stainless Cup Holders, Radio w/4 speaker and Subwoofer + Amp
    Lacey, WA
      That's what I assumed. The cap must have a two way valve. I'll see that the dealer says. Thanks
