Last year after winterising my Element i noticed some cracks in upper part of the hull (above the rubber band) (correct me if i am wrong about the names...) I did not found any impact for damage. My engineer told me that these are stress cracks. Do i need to worry about these cracks?
In point 4 of the lifetime hull warranty the following is stated:
- Damage or deterioration of cosmetic surface finishes, including cracking, crazing, discoloration, air voids, fading or oxidation of gel coat, wood finishes (varnishes, stains and paints), fabrics, vinyls, plastics, trim tape, plated or painted metal, stainless steel finishes, anti-fouling bottom paint, or zinc anodes;
It is definitely "broken" because i can feel the crack with my fingernail. Does this go under warranty and should i contact my dealer or is this the cosmetic surface finish?
Anybody has any experience with this?
