Does this estimate sound right
  • B95054
    started a topic Does this estimate sound right
    I just received an estimate for repowering our 2002 2859 from a 5.7 mpi to a 383 stroker. It also needs a new transom plate at the same time. The whole estimate with taxes came in at just over $27,000 CAD.
    i guess mentally I was just not ready for that number.
    When I look at the parts, most of the pricing all appears very fair.....but they have estimated 40 hours of labour and they added a $500 contingency on top for any additional surprises.
    Maybe I am way off but does swapping a complete engine package and transom plate really take 40 hours of labour if there are no additional problems? I have swapped many automotive engines, even with transferring all of the parts over (alternator, fuel systems, starter etc.) it was only ever a 2 day job at most and usually much quicker than that. This motor already has all the bells and whistles bolted on so it is just a matter of out with the old and in with the new. And of course changing the transom plate while the engine and out drive are out.
    Am I just severely underestimating the amount of work involved or is this really a full week job?
  • msd58
    The shop you are considering this job from could easily push that higher. At that point it may be more cost effective to get another boat.
  • SomeSailor
    I'd agree with Doug. You can get a reman'd motor from places like Michigan Motors for around $11K-$12K, get it home on a trailer and work off the $10K savings in labor.
  • dmcb
    I don't see why warranty would be an issue. You are not building the engine. You can trailer your boat with the right trailer. Maybe rent or borrow one and get it home to do the work. Now you can shop for the engine, maybe in the states.
  • johnswarts
    I'd call around to a couple of other marina to get their charge for this project.
    Most marinas have the Spader book with suggested times to do various jobs.
  • Solandri
    The PO had to replace the engine on my 2556. His invoice for a new 350 MAG MPI Horizon lists:
    - $16,003 for the engine, freshwater cooled
    - 8 hours @ $98/hr ($784 total) for labor
    - Misc parts and fluids brought it up to $17,869.73
    - CA taxes (British Columbia) brought the total to CA$20,371.49
    Make of it what you will. Work was done in 2006 if you want to try to adjust for exchange rate (on the engine) and inflation. There was a couple hundred bucks on a separate receipt for modifying the engine cover so it would fit (turns out the size was slightly different even though Mercruiser advertised it as a drop-in replacement). But I don't think you'll have that problem on a 2859.
  • TX H210 SS
    http://www.saferwholesale.com/MerCru...troker-383.htm
    I have no experience with this company, but they show a complete mercreiser 383 stroker package for $12,900 and includes EVERYTHING including bell housing, risers, wiring g harness with quick connect plug and spark plugs.....is this housing the plate your referring to?
    this package means zero swap over from old motor as everything is new, including spark plugs and fuel delivery system.
    if it were me and I had access to the forklift, I would strongly consider an option such as this and do it myself....warranty or not. Jerez, you could buy two complete packages and still come in under their estimate.
    Even worth paying a mechanic a 1,000 cash to come help one weekend
  • TX H210 SS
    I wonder if marine marine shops have standard book rates for work? I know auto shops do as my brother is a master toyota tech and has been for close to 30 years.
    It may be they aren't accounting for overlap of work. If the plate swap involves motor removal as the engine swap obviously does....if straight book rates are being charged for these jobs then you would be paying for engine pull and reinstall twice.
    Seems like any shop could give estimate for that job pretty quick.
  • Chief_Alen
    Maybe i should start charging, working for a ham sandwich most of the time, and bottled water.
  • MidnightSun
    I ordered 2x 383 turn key Mercruiser smartcraft fuel injected engines when I had my 1997 Avanti. Originally had 5.7 LX engines. As mentioned, footprint is the same. Did all the work myself and honestly it is a very easy job. Cannot comment on the transom plate as I never touched one but assume it is rather straight forward. I know "marine" prices are high but would never have expected the price they quoted you.
    I am surprised how much things have gone up. My swap was 10 years ago, both engines cost me 12,000 cdn, got 6,000 for my old engines so bottom line was it cost me 6,000 cdn to swap to 2 new engines. https://midnightsun.smugmug.com/Midn...os/i-vSZkR4z/A
  • B95054
    I am not opposed to doing most of the work myself. Although I am not sure how that affects the warranty. I even have access to a forklift so the re-and re does not intimidate me very much at all.
    If I can pay someone a reasonable price to do the work and it helps me when and if warranty issues arise - then I am good with paying a fair price. It just did not look like that bad of a job so I was floored when I received the estimate
    There were several replies about the parts pricing. It actually does not seem too bad to me. In CAD the engine with the additional riser kit is just shy of $13,000. The transom plate is just over $4000 (I know I can get them for around $3500 but still this does not completely throw the estimate way out.. They added a new prop which is about $1200 but I have the exact same prop in my garage so it will be getting axed from the estimate. The there is about $700 in haul out and hard storage for two weeks while the boat is on the hard. Of course lets not forget the governments cut which is about $2800 (talk about kicking a guy while he is down). Pre-tax, all totaled up it comes in just over $19,000 but when I chop the propeller out it drops down just under $18,000 and I may be able to squeeze another $1000 or so - but again that is not where the alarms bells lie.
    It is the 40 hour estimate plus $500 in the "just in case fund" that really caught me off-guard. It adds up to over $5500 in labor which just sounds way excessive to me and it sounds like most others here feel the same. I am out of town travelling right now but think I will go for a second quote when I get back.
    Thanks for the feedback everyone - I am glad to know that it is not just me that thinks something does not seem right.
  • The_Other_Gary
    Doing some of the work myself I built and swapped out a Cummins 6BTA marine diesel and my cost was 10,750 Canadian all in, including haulout and launch.
  • kwb
    R&R for entire time is not a 2 man job. There is about an hour (half in/out) where a helper is needed.
    I am not a mechanic but I did R&R of engine (same engine - long story) in my Contesa myself in less than 8hrs one day without the typical lift/hoist arrangement that a proper yard has. Swapping components between engines and misc cleanup stuff shouldn't be much more than a day. Can't say on the transom plate what that might add but even with sea trial more than 30 hours is excessive.
    Shop needs to make something on parts so using your catalog pricing isn't completely fair but if they have a breakdown of at least parts and labor you should be able to see where your expectations were violated.
  • Nauti_Mike
    commented on 's reply
    OP says his current engine is a 5.7 so should be easier than yours was.
  • RobMick
    I was going to say, 2 techs not one, 1/2 total time...20 hours x 2 men....plus its Canadian $$ isn't it? Did Canada go the Euro and I didn't hear about that?...will be following this
