Here are some digital service manuals and how to's.
Check Starter wiring Thanks goes to DonS http://www.4shared.com/file/103473187/9e0deaba/_2__Check_Starter_wiring_-_system.html Merc Throttle control manual. http://www.4shared.com/file/87245354/b072deb2/Throttle_control_manual.html Water in Boat Engine Bulletin. (This is a GREAT read to understand issues involved when dealing with water intrussion) http://www.4shared.com/file/90160824..._bulletin.html Test Boat Fuel System Thanks goes to DonS http://www.4shared.com/file/90160827...m_in_boat.html OMC MANUALS THANKS goes out to KRH1326 Seloc manual #3400 OMC 64-86 Repair Manual http://www.4shared.com/file/10298842...OMC_64-86.html Seloc manual #3404 OMC 86-98 Repair Manual http://www.4shared.com/file/10298911...-98_final.html Clymers manual for OMC Sterndrive/Engine Wiring Diagrams http://www.4shared.com/file/10298924...iring_all.html VOLVO MANUALS VOLVO 5.0 / 5.7 Engines Manual Thx to Don.S http://www.4shared.com/account/file/...ual_50-57.html VOLVO Electrical, Ignition, and Carb manual Thx to Don.S http://www.4shared.com/account/file/...Ign_30-57.html Volvo Penta Service Manual: 280 to DP-C Drive manual Thanks goes to vegasbayliner as I saved it from his upload http://www.4shared.com/file/51161054/39d7f699/Volvo_Penta_Workshop_Manual.html SX-DP-S_Service_Manual http://www.4shared.com/file/90160820...ce_Manual.html Volvo Service Manual AQ130 - 170 http://www.4shared.com/file/12235893..._Serv_Man.html Workshop Manual 230, 250, 251DOHC, AQ131, AQ151, AQ171 http://www.4shared.com/file/64741910...131151171.html MERCRUISER MANUALS NOTE.... Only some links are working If you can helpout with a file P.M me.. Thanks goes to Don.S for the mercruiser manual links and descriptions below Service Manual #1 1963- 1973 All Engines and drives http://www.4shared.com/file/11475212...d_drives.html? Service Manual #2 1974 to 1977 All Engines and drives. Service Manual #3 1978 - 1984 All engines Service Manual #4 1978 to 1982 120 to 260 Sterndrives Service Manual #5 1978 to 1993 TR - TRS outdrives Service Manual #6 R, MR, Alpha I outdrives 1983 to 1990 Service Manual #7 GM V6 1983 - 1993 Service Manual #8 1985 to 1989 Merc Marine 4 cyl (Newer 470's) Service Manual #9 1985-1988 GM V8 Service Manual #10 1985- 1989 GM 4 cylinder Service Manual #11 Bravo Outdrives 1988 to 1998 Service Manual #13 GM 4 cylinder engines. 1990 to 1997 http://www.4shared.com/file/11475277...0_to_1997.html Service Manual #14 Alpha I Gen II Outdrives 1991 to present http://www.4shared.com/file/11475364...o_present.html Service Manual #15 1989-1992 GM V8 Service Manual #16 1993-1997 GM V8 454 - 502 Gen V & amp; VI Service Manual #17 GM V8 305 and 350 cid (5.0L 93-95) 1993 - 1997 Service Manual #18 GM V6 Gen II with Balance Shaft 1993 - 1997 Service Manual #23 GM Big Block 1998 - 2001 Service Manual #24 GM Small Block V8 1998- 2001 http://www.4shared.com/file/11883531...e_Manual.html? Service Manual #24 Supplement GM 6,2L 98-01 Service Manual #25 GM V6 1998 - 2001 http://www.4shared.com/file/13725605...98_-_2001.html Service Manual #26 GM 4 Cyl 1998 http://www.4shared.com/file/11475427...998.html<br /> Service Manual #28 2001- newer Bravo drives. ALL Service Manual #30 2001 - newer 8.1L Service Manual #31 2001 - newer GM Small Block V8 Service Manual #32 2001 - newer GM V6 MPI Sections only must open and save each section Service Manual #33 555 Diagnostics Big Block Service Manual #36 555 Diagnostic Small Block V6 and V8 Here is a link to the Boatfix.com Merc manuals. These are not full downloadable but can link to different sections of manuals. In this link there will be pages to the left of the ADOBE window. Each section is for a different manual. For example Number 6 is for Alpha 1 manual, #16 is for the GM big block engines, #11 is for Bravo drive... ECT http://www.boatfix.com/merc/Servmanl/srvcovr.pdf Last edited by billbayliner; 10-03-2009 at 12:23 PM. |
Thanks for the credit Bill :-)
Two toasted back bacon sandwiches, hold the toast! See my YouTube Channel at http://www.youtube.com/user/VegasBayliner |
As a new boater your links were fantastics!!! I really appreciated the information.
David Quote:
SX-DP-S_Service_Manual added
Reported.
Donna ~~~~~~~~~ 2008 Trophy 2359 5.0 MPI w/FWC Bravo III Northstar M84 Plotter/GPS/Radar/A.I.S. "Joneva" MMSI: 338085296 |
Thanks, from the bottom of my outdrive to the top of my air cleaer. Thanks a lot.
Retired.... |
Unfortunately, none of the 4shared files are available
I could really use a link to the Volvo files af anyone has them. Chass ct
1985 2850 Sunbridge, VP 280 and 5.7, 2005 trailer. 1977 27' Victoria retired and being parted out. What do you need? |
Links Have Been fixed...... Found out I have to sign in at least once a month or the free account cleans out the files... Hopefully I will remember once a month.
Could someone walk me through the steps necessary to access 4shared? I'm trying to link up to the Alpha1Gen2 manual, and all get is an offer of love in the U.S.!
Any help would be appreciated. |
Anyone have a link?
'85 Ciera 2550 AQ260/280B |
| Thread Tools | |
| Display Modes | |
